Instrument cluster swap
Old Jan 24, 2016 | 01:43 AM
jconaway's Avatar
jconaway
Default Instrument cluster swap
My '04 Dakota SXT has the 4-gauge instrument cluster which uses idiot lights for oil pressure and voltage indicator. Is a 6-gauge cluster a simple direct swap (eBay has them pretty cheap) or is it more involved than that?
Old Jan 24, 2016 | 11:18 AM
00DakDan's Avatar
00DakDan
Section Moderator
What year is the cluster you want to get from?
The mileage is stored in the cluster, and the PCM.
Old Jan 24, 2016 | 11:31 AM
jconaway's Avatar
jconaway
I have a '03 parts truck which has almost the same exact number of miles as the '04 (and am aware of mileage disclosure requirements when selling a vehicle). From what I've read it seemed like the clusters from 01-04 might be compatible, but wasn't sure if the 2 additional gauges would work with the existing wiring and sending units or if there was some other difference (such as the PCM configuration) that would require the use of a cluster with the same combination of gauges/idiot lights as the truck was sold with.
Old Jan 24, 2016 | 03:22 PM
00DakDan's Avatar
00DakDan
Section Moderator
It should work.
The gauges and even the idiot lights are controlled by the cluster - a computer in itself. The PCM sends signals over the PCI bus. The lights aren't hard wired.
Give it a shot.
