p432 code
Old Jan 22, 2016 | 08:58 AM
jerseyboy69's Avatar
jerseyboy69
Default p432 code
just had o2 sensors replaced. would catalytic converter be the problem?
Old Jan 22, 2016 | 09:15 AM
Probably depending on which O2 sensor you replaced, what engine, how many miles?
00DakDan's Avatar
00DakDan
Section Moderator
Which O2 sensor(s) did you change?
What year is the truck/engine? P0432 is a 2/1 Catalyst Efficiency - yes it can be a bad catalyst.
If you used Bosch O2 sensors - change them out first. Dakota's do NOT like Bosch, there a lots of problems with them. Use Denso or NTK.
Old Jan 22, 2016 | 03:30 PM
jerseyboy69
3.9 v6 2001 dakota. both 02 sensors were replaced. 155,000 miles
Old Jan 22, 2016 | 03:58 PM
You failed to answer the question of what brand you used. This would be so much easier if you could provide as much info as possible so we don't have to keep asking this and that.
Old Jan 22, 2016 | 04:01 PM
jerseyboy69
looked at my invoice from shop and they did use bosch
Old Jan 22, 2016 | 04:36 PM
00DakDan's Avatar
00DakDan
Section Moderator
I'd change them out.
