I read about sludge on my 4.7 and i changed to synthetic amsoil and amsoil filters. i change oil once a year and have had no problems with sludge buildup
the thermostat I have in is from auto zone. I just did an oil change the other day and there was no sludge coming from the drain plug. so wat are some things I can do to find the cause of this
00DakDan gave you the best answer its normal but can be a bad head gasket especially with the 4.7.
Sludge/muck in the filler spout is common except out west the weather is not conducive to form it unless you live where it snows gets very cold.
Dodgevity
close
- Join DateOct 2013
- LocationAtlanta
Liked:449 Times in 401 Posts
You can rent a head gasket tester from the auto parts store. Will only cost you the fluid if you bring it back. The fluid is around six bucks.
How it works...
How it works...
RalphP
close
- Join DateJan 2013
- LocationNorthwest Louisiana
Liked:374 Times in 345 Posts
If it's due to the lack of engine run time, I'd just make sure the engine runs longer and gets hotter to boil the condensate out.
Or, you could move to someplace where the relative humidity never goes high enough ... say, the middle of Death Valley *grins*
(That's a, I say, that's a joke son!) /Foghorn_Leghorn_Voice
RwP
RwP
