Rough idle/p0305
Old May 17, 2016 | 04:31 PM
Supertruckman's Avatar
Supertruckman
Default Rough idle/p0305
I have an 03 dakota with the 3.9 and there is an engine code saying that i have a misfire on cylinder 5. It shakes when idling, and becomes less noticeable when driving. It still does good on fuel and i have replaced the distributer cap, spark plugs and wires, and the compression on each cylinder is good. Any ideas on what it could be next?
Old May 25, 2016 | 08:26 PM
00DakDan's Avatar
00DakDan
Section Moderator
Sorry Supertruckman, I just saw your thread and moved it into the correct forum.
Could be a vacuum leak, running lean. How's your plenum plate? Do you see oil/crud looking down the throttle body? Using any oil?
