TPS, 11% to 78%?
Old May 24, 2016 | 09:37 AM
Robbadodge's Avatar
Robbadodge
Default TPS, 11% to 78%?
My son was helping me review codes when he noticed the TPS was reading 11% (key on and engine off). He then pressed the accelerator to the floor and read 78% max. He repeated and got the same results.
I am not freaking out, just curious if an adjustment needs to be made or if anything should be done.
Thanks in advance,
Robb
Old May 24, 2016 | 10:08 AM
00DakDan's Avatar
00DakDan
Section Moderator
Nope.
Typical for a Dodge at idle would be about .60 volts or just about 11% of the 5 volt nominal supply. At WOT, 3.5 to 4.5 would be typical, so your 77% is about right in the middle of the range.
No problems.
Old May 24, 2016 | 01:11 PM
Robbadodge's Avatar
Robbadodge
Thanks for spelling it out. Appreciate the quick reply.
