Bad hub or what?
Old May 24, 2016 | 01:21 PM
Robbadodge's Avatar
Robbadodge
Default Bad hub or what?
Just replaced my DS front hub assembly last night after months of hearing the grind. Maybe I should have tested it...
New Timken gives me noise like a bad hub!? Right turn noise puts load on left side indicating bad left hub.
Can a new hub be bad?
Can something in the 4X4 drive train cause a grind, only going straight or rh turns/curves? Left turn = no noise.
I described it as grind, it's just noise coming through to the steering wheel.
I have not checked the front diff for fluid or lack there of. Shame on me for assuming!
Old May 24, 2016 | 01:33 PM
98DAKAZ's Avatar
98DAKAZ
Not sure with a 4X4 but 2wd the proper torque is extremely important to not damaging the new bearings.
Old May 24, 2016 | 03:02 PM
Robbadodge's Avatar
Robbadodge
185 foot pounds for the axle nut, check!
And thank you.
Old May 24, 2016 | 03:56 PM
00DakDan's Avatar
00DakDan
Section Moderator
Yes a new hub can be bad. It may also be your RH hub. I know, usually with a right turn the left one gets noisy if it's bad - but not always!
Old May 24, 2016 | 07:00 PM
98DAKAZ's Avatar
98DAKAZ
Talking
I remember when I was almost at the proper torque the nut just kind of popped/slipped in right at that correct torque like it was meant to be kind of weird then it clicked OK done.
