No Bus
Old Jun 4, 2016 | 04:02 PM
  #21
David Dudemaine's Avatar
David Dudemaine
Update:
So it's not the crankshaft position sensor. I went to another store for code reading and they got no codes. Maybe camshaft position sensor (which they don't sell, only whole distributor assembly) so I didn't buy.
If my mechanic did put a second hand PCM in, I wouldn't need it flashed by the dodge dealer would I?
Old Jun 4, 2016 | 04:11 PM
  #22
David Dudemaine
I also unplugged the cam shaft position sensor and tried to start but wouldn't turn over. I just wanted to see if the lights would turn off which they didn't. Thought I mention that as well.
Old Jun 4, 2016 | 09:10 PM
  #23
00DakDan's Avatar
00DakDan
Section Moderator
It won't start without the cam position sensor, nor will the lights turn off.
With no bus you probably won't get a code.
Old Jun 5, 2016 | 09:37 AM
  #24
David Dudemaine
I ordered a new cam shaft position sensor. It will take two days....
Old Jun 6, 2016 | 10:53 AM
  #25
David Dudemaine
So I went and put a used PCM in and gauges worked but I got a code 12 on odometer. Also it had a very rough idle so I didn't buy PCM. Should I have? Thx
Old Jun 6, 2016 | 03:40 PM
  #26
00DakDan's Avatar
00DakDan
Section Moderator
Code 12? p0012 or just a 12?
Old Jun 6, 2016 | 04:47 PM
  #27
David Dudemaine
Just a 12
Old Jun 6, 2016 | 05:05 PM
  #28
David Dudemaine
Also, I found out that the PCM in my truck is for a Dodge Ram/ Van 5.9L instead of a Dakota 5.2L. So there's the reason for the no bus. Wrong PCM was put in by shady mechanic. I am pissed off because I've done a lot of business w him over the last two years. Anyways, I have to look at two PCMs tonight for the truck and hopefully it won't idle crazy. It was acting like it was misfiring and choking out. I hope the second PCM works better than the first one that game me the code 12. But all the gauges worked on the cluster so the cluster is good.
Old Jun 6, 2016 | 09:28 PM
  #29
David Dudemaine
So I started a new thread to update called Code 12
Old Jun 7, 2016 | 08:34 PM
  #30
David Dudemaine
So I put in computer at autozone and got P1391
And P0320. They have to do with the crank signal to PCM. I just replaced the sensor 2 days ago. Wtf. Maybe I got a bad sensor. I will replace tomorrow
