blinking check engine light
May 26, 2016 | 07:19 PM
recently my check engine light started to blink but only when I turn the key to accessory, engine not running.
can someone please tell me what this means?
The check engine light is not on but when I connect a scanner I get a
pending code of PO141.
May 26, 2016 | 07:31 PM
Does it blink when running?
May 26, 2016 | 07:37 PM
it used to blink when running but I replaced oxygen sensors all 4 and coil on plug ignition coils
May 26, 2016 | 07:38 PM
I bought walker oxygen sensors and they are junk. misfired when I had them installed.
May 26, 2016 | 08:31 PM
Use NTK or Denso O2 sensors. No Bosch!
Jun 1, 2016 | 06:41 PM
generally if the light is blinking while it is running it is an active code. A p0141 is an O 2 sensor code.
Jun 2, 2016 | 05:29 PM
PO141 oxygen sensor code
po141 code keeps coming on even when I replaced that oxygen sensor twice.
I have checked the wiring and looks good.
what else could keep this same check engine light po141 keep coming on.
Jun 2, 2016 | 06:39 PM
The only way I can clear the PO141 code is to disconnect the 4 plugs on the ecu engine computer. Then it goes away for 2 days or so. then comes back.
Jun 2, 2016 | 06:40 PM
replaced affected oxygen sensor twice with no result
How can I be sure that it is not my ecu thats bad? engine computer.
