Lower ball joint
Old May 30, 2016 | 04:53 PM
John3475's Avatar
John3475
Default Lower ball joint
Can you replace the lower oem ball joint without removing the axle assembly. Can you just separate the upper and lower ***** and have enough room to press out old and press in new?
Old May 30, 2016 | 08:33 PM
00DakDan's Avatar
00DakDan
Section Moderator
The upper isn't difficult to do. Just drill out the rivets (if OEM) and replace with bolts. You can do it with the axle in place.
The lower, it's tight. You'll need to disconnect the spindle and then keep it and the axle out of the way. The press will likely get in the way.
Old May 31, 2016 | 05:41 AM
Dodgevity's Avatar
Dodgevity
When I did mine, I discovered it was the uppers that were worn. The lowers were still in decent shape, but I changed them anyway.
Old May 31, 2016 | 10:17 PM
00DakDan's Avatar
00DakDan
Section Moderator
Same here. I've put two sets of uppers on the truck, still the OEM lowers. It surprises me every time I check them.
Old Jun 1, 2016 | 07:48 AM
John3475's Avatar
John3475
101k on the truck and I'm doing tops and bottoms and bushings. Never done this before so the first side is the learning curve.
I could not pop the lower with the fork ,so I used the sawzall and cut it.
