Hello all I have a 2002 Dakota slt
Old Jan 11, 2017 | 10:08 PM
2002 dakota's Avatar
2002 dakota
Default Hello all I have a 2002 Dakota slt
I have a 2002 Dakota slt 4x4 with the 4.7 what engines swap into this with its current wiring? Yes I know 2002 4.7 but is there other years or if there are better years what is needed to put them in?
Old Jan 12, 2017 | 09:24 PM
00DakDan's Avatar
00DakDan
Section Moderator
2002 was a transition year so look at your PCM. How many wire connectors are there?
If you have 3 you are running a JTEC controller. It's a 16 tooth tone ring.
If you have 4 you are running the NGC controller. It's a 32 tooth tone ring.
The tone rings aren't compatible. There is one on the crank and one on the RH camshaft. The crank has to come out to swap.
Later years offer more "improvements" to power/torque/fuel economy.
Old Jan 13, 2017 | 08:34 AM
2002 dakota
Thank you will keep this in mind..what is the better years for the ngc engines and is there a difference in vehicles car vs truck that the 4.7 was used in....so if I have the ngc what vehicles are my better donors to look for when searching for a engine..?
Old Jan 13, 2017 | 10:23 AM
00DakDan's Avatar
00DakDan
Section Moderator
Later years are more likely to be "better" in terms of horsepower and torque. There were changes to the cam and in later years they even had dual plugs.
You'd have to check the individual specs.
The 4.7 was also used in some Jeep vehicles and Ram pickups. The specs do differ some.
Old Jan 13, 2017 | 11:25 AM
2002 dakota
Will a 04 thru 12 4.7 work in my 02? Is there pcm or electrical differences to worry about?
Old Jan 13, 2017 | 01:47 PM
00DakDan's Avatar
00DakDan
Section Moderator
Later years have 16 spark plugs but you can wire the coils together.
You need to check your PCM for the number of connectors before doing anything.
Physically the engines are the same dimensions but the intake/exhaust manifolds vary.
