need e fan help asap
Old Mar 12, 2017 | 05:07 PM
Jeff Wheeler's Avatar
Jeff Wheeler
Default need e fan help asap
Installed an e fan on my Dakota today. The fan does not come on at all and the truck overheats. I have the thermostat tapped into the cooling system and ignition wired to the stereo. What's going on?
Old Mar 12, 2017 | 05:38 PM
00DakDan's Avatar
00DakDan
Section Moderator
Year/Engine?
Can you post a schematic of your wiring?
Is there a relay in there somewhere?
Old Mar 12, 2017 | 05:49 PM
Jeff Wheeler
Yes there is a relay and here is the diagram
Old Mar 12, 2017 | 06:18 PM
Dodgevity's Avatar
Dodgevity
Try hooking up power directly to the fan, to see if works.
Old Mar 12, 2017 | 06:25 PM
magnethead's Avatar
magnethead
Is the fan grounded?
Old Mar 12, 2017 | 06:31 PM
Jeff Wheeler
It works with direct power
Old Mar 12, 2017 | 07:57 PM
magnethead's Avatar
magnethead
I see the problem and it may not be one you can easily fix. the thermostat threads need to be grounded to activate the relay coil to pass current. Depending on where you have it threaded into, it may not be grounded. It's a rather cheap/chinsey setup. You get what you pay for.
Old Mar 12, 2017 | 08:10 PM
Jeff Wheeler
Ok waiting for my truck to heat up now and I'll try it
Old Mar 12, 2017 | 08:19 PM
Jeff Wheeler
Well that was the problem. Thank you so much! I've been stressing for hours lol can't believe it was something so simple
Old Mar 13, 2017 | 06:42 AM
Jeff Wheeler
So now that the t stat is grounded there is another issue. The fan is constantly running and won't shut off. It starts as soon as the key is on
