Sequence number is worn off the ECM/PCM.
Old Mar 30, 2017 | 11:08 PM
Jojabe's Avatar
Jojabe
Default Sequence number is worn off the ECM/PCM.
So I bought my Dakota sport at an Auction. I drove it a couple days and it kept "cutting out". On the second day it would not fire. I was told ECM. I bought another one from a 2001 dakota, this one was standard. It blew because I did not match the sequencing numbers which are worn off of mine, can I get the correct sequence numbers from the vin somewhere?
Old Apr 3, 2017 | 09:19 AM
00DakDan's Avatar
00DakDan
Section Moderator
Most rebuilders can program the PCM for you via the VIN. They'll look up the option codes and set them. You just provide them with some info first.
Old May 19, 2019 | 04:00 AM
Casey Acosta's Avatar
Casey Acosta
Default Same issue
Hello. How did you go about getting this issue resolve. I’m literally going through the same thing at the moment.
Old May 19, 2019 | 10:11 AM
Dodgevity's Avatar
Dodgevity
Don't hold your breath waiting on a reply. OP has a post count of 1.
