Alternator
Old Apr 22, 2017 | 06:00 PM
dodgedakotaslt's Avatar
dodgedakotaslt
Default Alternator
hello there guys i have a quick question can i replace the alternator's voltage regulator or do i have to replace the whole alternator.
Thanx Derrick
Old Apr 22, 2017 | 06:58 PM
Dodgevity's Avatar
Dodgevity
Thanx Derrick
From what I can recall, the voltage regulator is not a part of the alternator and is built into the PCM. What issue are you having?
Old Apr 22, 2017 | 08:49 PM
dodgedakotaslt
When i was going home this afternoon my check gauge light came and the battery gauge wasnt working. so when i got home i turn the truck off and then it wouldnt start so i had the alternator and battery tested and they both passed. I just havent tried starting it up yet i was gonna wait til morning.
Old Apr 22, 2017 | 10:32 PM
Dodgevity's Avatar
Dodgevity
I actually assumed that you have a 4.7L engine, which I shouldn't have. LMK if that isn't the case. Either way, I suggest pulling the alternator and having it tested while out of the truck.
Old Apr 23, 2017 | 07:42 AM
98DAKAZ's Avatar
98DAKAZ
Lightbulb
If both tested ok next to check would be the battery temp sensor its under the battery it can cause charging problems, also check your connections for corrosion.
Old Apr 23, 2017 | 08:14 AM
dodgedakotaslt
Ok thanx for the help guys ill check up on the senser today and no there is no corrosion
Old Apr 23, 2017 | 10:10 AM
98DAKAZ's Avatar
98DAKAZ
Dont know your year but it fits a 98 to 05 Dakota
http://www.rockauto.com/en/moreinfo....353978&jsn=446
Old Apr 23, 2017 | 10:14 AM
Dodgevity's Avatar
Dodgevity
If the issue was the battery temp sensor, I think it would be throwing a P1492 code. I had my Alt tested while still in the truck and was told it was good. Pulled the alt and two tests said bad. Changed the alt and all is well.
Old Apr 23, 2017 | 10:27 AM
dodgedakotaslt
The check gauge came back on but when i restart the truck it doesnt come on yet
Old Apr 23, 2017 | 10:42 AM
dodgedakotaslt
I pulled both the alt and battery and they both passed but im gonna try replacing the battery senser
