Default ac/heater works when it wants to, but when it does come on all 100% of it is
I have an 2000 Dodge Dakota extended cab V6 automatic and I'm having ac/heater problems. I'm not getting any air hot or cold blowing out, but when I get on the highway a very small amount will blow out. Days will go by and then out of nowhere the blower well start to work and blow perfectly fine on all speeds for both ac/heater for a day or so and then when I turn it off and back on again within the same day it may or may not work. And then the next day I start it up more than likely it doesn't work. And then next month it may or may not do the same thing again. Like one day every 2 or 3 months. Completely random. I've tried buying a new ac/heater control climate/blower/vent switch, but that didn't fix it. Please help.
Thank you very much. I'm going to check those things out. Would you happen to have an exact location of the resistor block? I've seen some videos where you can remove the floor duct to access it while laying on your back on the passenger floor board. And then there are others that say you have to remove the glove box or the top part of the dashboard to access it. I'd rather know for sure as to it's location before I start disassembling. LOL
