a\c not worling
a\c not worling
After swapping all the wiring and interior from my 99 to my 97 i was going to charge my a\c but the clutch will not kick on. i didn't even feel the relay click. The clutch doesn't kick on for either the 97 or the 99 but it used to work on my 97 before i swapped everything. im pretty sure i had to change both the high and low pressure switches so the system was completely emptied on my 97. i did go ahead and spray a little bit of r134a into it to see if it would kick on but it didn't so i gave up. the only thing i have tried is swapping a relay for a known good and still nothing. any other ideas from anyone more familiar with the a\c systems would be greatly appreciated.
I think I fixed the leaks so that cant be an issue anymore. When i jumped the low pressure switch the truck idled up like the clutch kicked on but nothing. When I plugged the switch back in it idled up the same way but still nothing. If i unplug the relay and plug it back in i can feel it click and turning the control switch to air or defroster the truck idles up but still doesn't kick the clutch on. I can turn the clutch by hand so it's not stuck. I will try jumping the clutch to a battery and see what happens. Does the battery have to be 12v?
Trending Topics
Got the compressor swapped and put enough stuff in to get the clutch to kick on. Now it kicks on for about 2 seconds then back off. While it is on, the crappy little gauge for the can of r134a drops almost completely and while the clutch is off it sits wherever i stop putting more in at. Right now that is in the yellow "warning" area on the gauge past the full area. It is not blowing even a little cool inside the truck. Is there something i can do to get it working right or should i leave well enough alone and take it to a "professional"?
