Engine 1 fuse keeps blowing.
I found it in the FSM- page 8W-10-14, 8W-10-22, and 8W-52-2. Engine Fuse 1 30A in the PDC feeds pin 61 of Connector 200 (Black/white), which goes to the combination flasher as trace L9.
Fuse 1 is the constant-power fuse for the combination flasher (pin A1 Black/White). The Combination Switch is also powered by Fuse 19 when the ignition is hot (run/acc, Pin A6 Black).
The outputs of the combination switch are: Brake Lamp Output, two left turn signals, and two right turn signals. The Combination Switch receives input from the Multi-Function switch.
I found the diagram, 8W-10-2. F/L 11 ASD. Feeds Circuit A16 (14 Gray). Feeds ASD relay (8W-10-15), Fuse U (8W-10-27), and Splice 110. Splice 110 then feeds the PCM, fuel injectors, and fuel pump (8W-10-31).
