98 Dakota transmission problems
Old Aug 16, 2017 | 09:53 PM
nschuls's Avatar
nschuls
Default 98 Dakota transmission problems
I have a 98 Dakota 5.2l. a few months ago i was driving when the trans temp light came on and the overdrive light came on. Then half an hour later the transmission goes into 4th or 5th gear and will not downshift unless i manually do it. After trying to fix the problem there were no gauges that came on and it didn't start until I went and unplugged the wires on top of the transmission. Everything worked except it is still staying in high gear and when i plug the connector back in it shuts off and wont start until i unplug it. Does anyone know about this problem?
Old Aug 16, 2017 | 10:18 PM
Any codes? Which connector are you unplugging? There is a bunch of them in that area.
Old Aug 16, 2017 | 10:24 PM
nschuls's Avatar
nschuls
i am unplugging the bigger connector that sits on the top driver side of the transmission and codes are P0753 and P0713 but the code reader only works when i unplug the transmission
Old Aug 17, 2017 | 08:23 AM
I suspect there is a short in the trans harness then. (probably internal.....)
