97 crank no start
Old Sep 6, 2017 | 09:30 PM
98darryl's Avatar
98darryl
Default 97 crank no start
So ive read and read with no luck...i have a 97 dakota 5.2 5 speed 4wd i have replaced the crank sensor 5 times, has new distributor, plugs, wires, coil, fuel pump, and most recent i replaced the computer.....had a mechanic friend check all wiring and said it was ok....i put old coil back in andit started but missea and backfires like crazy and is still throwin a crank sensor code with a brand new crank sensor in it....any help would be greatly appreciated
Old Sep 6, 2017 | 09:52 PM
What brand crank sensor? If it's duralast.... I suspect right there is your problem.
Get one from the dealer, install it. Wouldn't be surprised if it didn't solve the problem.
Old Sep 7, 2017 | 07:25 AM
98darryl's Avatar
98darryl
I got all 5 from autozone....jus hard to believe all 5 were bad
Old Sep 7, 2017 | 09:22 AM
Not necessarily 'bad', just our trucks don't like 'em. If everything else tests good, that leaves the sensor itself.
Old Sep 7, 2017 | 10:26 PM
magnethead's Avatar
magnethead
Which code are you getting. There's 3 different ones for Crank sensor I believe.
