front driveshaft
Old Sep 27, 2017 | 06:50 PM
92DakotaClub's Avatar
92DakotaClub
Default front driveshaft
so after finding the cv-joint obliterated on my Dakota's front drive shaft , found a driveline shop that will replace it with a normal u-joint style instead, says does it a lot with this style driveshaft with no issues...
my question is... is there any disadvantage or problems to having a ujoint setup on the t-case side over the cv joint?
I know lotta vehicles don't require it but being AWD .... primarily front drive.. this is different then most ive seen ..
Old Sep 27, 2017 | 09:38 PM
You have independent front suspension right? So, the front axle is solid mounted. That means that the d/s runs at a constant angle, doesn't need to deal with angle, or length changes as the suspension cycles. I really don't see it being a problem.
Old Sep 30, 2017 | 10:14 AM
92DakotaClub
after looking at angle it actually runs the driveline shop dosent even see the need for a double cardan joint the angle is only a few degrees , and wonders why it required a cv joint to begin with, but in the end he said it it has vibration issues or anything he will simply try and rectify it, order a cv replacement or refund eitherway .. in the end it will still bolt right up to the stock 6 bolt round flange.. so no other changes will be required
Old Sep 30, 2017 | 12:31 PM
Sounds like a plan. I agree with your shop. Likely the joint they used was simply cheaper than the double-cardan...... even if its only a few cents, when you are cranking out 100K or more of them, it adds up quick.
Old Oct 3, 2017 | 12:27 PM
92DakotaClub
this was the outcome of scrapping the cv joint ... pic 1 is the replacement spicer 1310's greaseless and mounting to mount to stock t-case output..
sandblasted balanced and painted.. looks like a brand new shaft total cost was still cheaper then replacement shaft from rock auto and this is probably stronger then a cv joint.. who knows but atleast I can service this myself with a new u-joint if it does wear down..lol
Old Oct 3, 2017 | 03:54 PM
Looks good.
