Clutch bleeding
Old Oct 26, 2017 | 10:04 AM
Tony1072's Avatar
Tony1072
Default Clutch bleeding
Replaced both clutch master and slave cylinders. No fluid getting to slave. Could the line itself be bad?
Old Oct 26, 2017 | 12:05 PM
Possible. It should gravity bleed to an extent.
Old Oct 26, 2017 | 01:47 PM
00DakDan's Avatar
00DakDan
Section Moderator
Usually the clutch master and slave cylinders come as an assembly with the tubing between the two. They're also usually pre-bled.
