Dakota ABS issue
Old Nov 9, 2017 | 01:41 PM
partsman57's Avatar
partsman57
Default Dakota ABS issue
Hey y'all. I'm Jeff and I am new to the forum. I've owned nothing but Mopars for 40 years, and currently own 2 second gen Daks. A 99 2wd 3.9 automatic and a 04 4wd 3.7 5spd. I'll throw up some pics later, but right now I wonder if I can get some help. The 04 is in the shop with what the owner/lead tech is telling me is a stuck ABS dump valve. The new part having been discontinued from Mother Mopar, we went with used but are having trouble finding a good one. Does anyone here know where a new or re-manufactured valve can be found? Thank you in advance for any assistance.
Old Nov 9, 2017 | 02:27 PM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum Jeff.
Do you have a part number?
Many parts are specific to the VIN. If you haven't yet, try going to a Dodge dealer. Dodge does re-manufacture parts as well.
Old Nov 9, 2017 | 04:31 PM
partsman57's Avatar
partsman57
Thanks for the quick response. I'm tied into the Mopar Parts site, but the part number has been discontinued and a follow up called to the dealer confirmed this. The local dealer network showed none and we, (the shop owner and I) are now searching nationally but after 3 days have had no luck.
Old Nov 9, 2017 | 05:56 PM
magnethead's Avatar
magnethead
I am assuming this is an RWAL unit. Reference my thread here: https://dodgeforum.com/forum/2nd-gen...g-diagram.html
Good news: This is more common than it should be.
Okay news: The unit is rebuildable (with some good know-how).
Bad News: The ABS on these trucks sucks anyways.
Remove the shield covers, lift up on the coil assembly. This reveals the solenoid plungers. Using a deep socket, remove the plungers from the ABS block. If they can't get a socket to fit right, I ended up using a pair of vise grips on the shaft itself.
You might have them look up an RWAL Kelsey-Hayes module for a Ram or RamVan. They are pretty much the same, but the shop may have to re-flare the brake lines...some are metric and some are english.
I took my valve all the way out and put a proportioning valve in, then used the old harness to put resistors across to turn off the ABS light.
Old Nov 10, 2017 | 08:30 AM
partsman57's Avatar
partsman57
Appreciate the good info Magnethead. Thought about the proportioning valve idea. Along that line I'm thinking something adjustable for the front/rear bias. Never been a big fan of ABS anyway. Thanks for the help!
Old Nov 10, 2017 | 09:25 AM
Dodgevity's Avatar
Dodgevity
It's saved my *** once or twice. I've learned to "exercise" it every now and then on wet roads.
Old Nov 10, 2017 | 09:33 AM
partsman57's Avatar
partsman57
I hear you. I prefer to exercise my pedal pressure via my left foot, but I'm sure there are situations where ABS might be useful especially on a slippery surface. I've found that for me, steering and a little acceleration can get me out of most bad spots.
Old Nov 10, 2017 | 12:53 PM
magnethead's Avatar
magnethead
It's cost me a few times when I needed the backs to lock and they didn't. I learned to throw my left foot on the E-brake pedal for those situations, and use my right foot for the front brakes.
