Engine swap
Old Nov 10, 2017 | 10:50 PM
Jocam75's Avatar
Jocam75
Default Engine swap
I have a 96 Dakota 2wd with 3.9, can I swap the 318 from a 94 Dakota4X4 and it's computer and wiring harness and put it in my 96. Any help would be much appreciated.
Old Nov 11, 2017 | 07:56 AM
Nope. 94 is OBDI, 96 should be OBDII, If you have an automatic trans, the PCM will have no provisions for running it. You need the electronics (PCM, wiring harness) from a 96 or newer truck, and there is likely an upper limit on that as well.....
Welcome to DF!
Old Nov 11, 2017 | 08:14 AM
Jocam75's Avatar
Jocam75
Thank u. Back to the drawing bored . Bout to strip every wire out and go old school, carberated the heck with all them sensors an computers
Old Nov 11, 2017 | 07:28 PM
If you have an automatic trans, still need the PCM to run it.
