black heater core box vacuum line
Old Dec 7, 2017 | 06:09 PM
noahj01's Avatar
noahj01
Default black heater core box vacuum line
I replaced the heater core on my dodge Dakota a couple of weeks ago and when I put everything back in I had heat again but only in defrost and on my feet. under the drivers side there is a black hose coming out of the box holding the heater core is that the reason hat does not come out of the vents? and if so were would the hose go?
Old Dec 7, 2017 | 10:07 PM
Pic of the hose?
Do your vents switch at all? If not, I suspect your hose is a vacuum line......
Old Dec 8, 2017 | 03:13 PM
noahj01's Avatar
noahj01
Pic of the hose?
the vents will switch from defrost to the floor but the air won't come through the dash
Old Dec 8, 2017 | 03:34 PM
That line likely goes to another actuator somewhere then. Not sure exactly where it is in your truck......
