Ian having problems after problems
Old Jan 30, 2018 | 03:39 PM
Tj Jeffries's Avatar
Tj Jeffries
Question Ian having problems after problems
My 03 dodge dakota 4.7l is putting up a p0121 codes but I have replaced the tps and connector to the tps and I have done a hard reset with the battery and the code is still coming up it idles a little high but when I put in gear it idles down way too low lower than when I first had it but my question is would it ha e to do with replacing a map sensor or what other things
Old Jan 31, 2018 | 11:06 AM
Does you pedal have an actual cable running to the throttle body? Or is that drive-by-wire?
Old Feb 2, 2018 | 10:58 PM
Tj Jeffries
Ian sorry it's not drive by wire it's got a cable going to the throttle body and when I mess with the Orange connector to the computer it shuts off do i have a problem with the computer
Old Feb 3, 2018 | 09:35 AM
Too many parts in that setup....... Need to plug in with a scanner, and see what the PCM thinks the pedal, and throttle are doing.
Old May 5, 2019 | 05:14 PM
Alan Patty's Avatar
Alan Patty
Default 2001,318 motor got it started 2 times run 5 min total won't start back what should I
There is no sound at all from fuel pump checked it from the undercarriage while I had some turn the key,thanks for your time by the way,Thanks
Old May 5, 2019 | 05:20 PM
Alan Patty's Avatar
Alan Patty
Default 2001,ram van,318 started2 times run 5 min total won't start back what
Found a place in Illinois for 99 bucks will rebuild my PCM that way it will match my van.
Old May 5, 2019 | 05:21 PM
Alan Patty's Avatar
Alan Patty
The guessing game gets expensive
