Transmission line o rings
Old Mar 3, 2018 | 09:47 PM
hidden1's Avatar
hidden1
Default Transmission line o rings
I'm replacing the radiator soon on the 01 dakota.
​​​​​will I need any o rings where cooler lines go in?
Old Mar 4, 2018 | 12:44 AM
magnethead's Avatar
magnethead
No, they should be fine, should come out in one piece.
Old Mar 4, 2018 | 01:09 AM
hidden1's Avatar
hidden1
Ok thanks..
So no seal or rings .
​​​​​will I need to use pipe tape or anything to help seal at radiator?
Old Mar 4, 2018 | 01:15 AM
magnethead's Avatar
magnethead
No, the O-Rings do the sealing. I forget the name of the fitting, but it's similar to 37 degree AN fittings. Self sealing, dry threads.
Old Mar 4, 2018 | 01:18 AM
hidden1's Avatar
hidden1
So there ARE o rings?
Old Mar 4, 2018 | 01:19 AM
magnethead's Avatar
magnethead
Yes there is an O-ring on each line, but they should come out of the old radiator and go into the new one just fine, I never replaced mine.
Old Mar 7, 2018 | 09:44 PM
hidden1's Avatar
hidden1
Yep .
There were o rings on end of transmission lines,in fact one was missing on the lower line.
Half the size of a dime.It was tan.
Will the basic black o rings work fine mixing with that transmission fluid ?
Old Mar 8, 2018 | 12:35 PM
magnethead's Avatar
magnethead
Black O-ring should be fine. Hard to say what size they are. Most O'Reilly's keep O-rings in a little yellow box behind the counter. #011 is a 5/16 ID i know for a fact.
