Con Rod bearing issues
Old Apr 7, 2018 | 12:56 PM
ChelseaM's Avatar
ChelseaM
Default Con Rod bearing issues
Im in the process of swapping out my V6 in my 2003 Dakota for a 318 our of a 1998.
Im at the stage of replacing the con rod bearings - I put 4 in (not fully torqued) and the engine will turn by hand, but I put the other 4 in (also not fully torqued) and it won’t move.
Have measured the con rod journals and and they are within spec and the bearings are standard.
Not it sure what could be happening - any suggestions or infor would be greatly appreciated.
Old Apr 8, 2018 | 12:19 PM
Did you pull the pistons out of the block to change those bearings?
First thing I would suspect would be bearings installed in wrong orientation.
Old Apr 8, 2018 | 07:14 PM
ChelseaM's Avatar
ChelseaM
Yes - I pulled the pistons out and changed the rings on them. Each piston was numbered and marked as to its location. I also checked the clearance of each ring before installing on the piston.
The bearings can only go in one way as they have tabs on them. The caps match with rods (oil holes line up)
Old Apr 9, 2018 | 08:09 PM
00DakDan's Avatar
00DakDan
Section Moderator
How much clearance do you have between the bearing shell and the conn rod journal?
Old Apr 9, 2018 | 11:11 PM
magnethead's Avatar
magnethead
Need to measure your clearance. Should have .0015-.0002 or so total. Maybe a hair more.
