1998 Dakota Fuel Gauge not working
Old May 1, 2018 | 10:38 AM
Ryan Marshall's Avatar
Ryan Marshall
Default 1998 Dakota Fuel Gauge not working
New fuel pump, which has the sending unit built in, still the fuel gauge works sometimes and does not most of the time. Needs some help.
Old May 1, 2018 | 09:39 PM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum Ryan.
The fuel gauge connects to the PCM and provides a signal over the CCD bus (network) to the instrument cluster. Check all connections at the pump and PCM.
Unfortunately, I don't have wiring diagrams for a '98. In '00, the last year for the CCD bus, it would be Connector 1 pin 4 for the sensor ground and Connector 3 pin 26 for the fuel level sensor signal.
