Wiring Harness to Headlight Switch Colors Mismatched
Old May 13, 2018 | 05:06 PM
NeikohTrixster's Avatar
NeikohTrixster
Angry Wiring Harness to Headlight Switch Colors Mismatched
SORRY MODERATOR: there is no clear place to post Dakota related tech questions...
I have a 1997 Dakota, 3.9, and bought an aftermarket pigtail and headlight switch... My problem is that the wire colors on the new pigtail do not match the wire colors coming from the truck!
THE COLORS FROM THE NEW CONNECTOR ARE:
B1 - RED
B2 - PINK
B3 - BLUE
D - YELLOW
H - GREEN
P - GREEN/WHITE
R - BLACK/YELLOW
U - BLACK
I - TAN
THANKS IN ADVANCE!
NeikohTrixster
1997 Dakota 2D/2WD
3.9 V-6 Magnum / 5 Speed
Old May 13, 2018 | 09:15 PM
How about in the 2nd gen dakota section, with all the other tech threads? This is currently in general discussion. I'll move it out.
Old May 14, 2018 | 02:11 AM
dalewpitt's Avatar
dalewpitt
Not sure exactly what you are looking for. This is the Headlight switch connector pin out from the FSM. If you look at the "sticky" pages in 2cd gen you'll find a link to the Factory Service Manual..
HEADLAMP SWITCH - BLACK 8 WAY
CAV CIRCUIT FUNCTION
1 - -
2 - -
3 Y163 20OR/WT HEADLAMP SWITCH ILLUMINATION CONTROL
4 Z214 20LB/BK GROUND
5 L39 20LB FOGLAMP RELAY OUTPUT
6 Y111 20VT/WT PANEL LAMPS DIMMER SIGNAL
7 Y167 20WT/DB HEADLAMP SWITCH RETURN
8 Y126 20VT/YL HEADLAMP SWITCH SIGNAL
