starting problems
Old May 14, 2018 | 10:58 AM
98DAKAZ's Avatar
98DAKAZ
Unhappy starting problems
She has been hard to start on and off great a few days then hard to start. She died on me two times today that sucked.
When I crank it it shows Im empty fuel gauge doesn't move what is this fuel pump going bad?
I have half a tank
Old May 14, 2018 | 11:12 AM
98DAKAZ's Avatar
98DAKAZ
Unhappy
Well RATS Its the fuel pump at key on I just hear it and it sounds anemic just a small sick sound.
When it rains it pours I guess my truck sitting a month many things died on me.
Getting a fuel pressure tester in a day or two just to be sure.
What pressure should I see?
Old May 14, 2018 | 04:48 PM
Throttle body, or port injection?
Old May 14, 2018 | 05:59 PM
98DAKAZ's Avatar
98DAKAZ
Throttle body
Old May 14, 2018 | 08:48 PM
98DAKAZ's Avatar
98DAKAZ
Cool
Well a shop checked it out fuel pump is fluctuating all other things check out ok.
I suspect the pump just kicks off at times its holding on by a hair in zombie half dead fuel pump mode.
How fun $800
Old May 15, 2018 | 04:31 PM
Holy smokes. That seems a tad steep......
Old May 15, 2018 | 08:35 PM
magnethead's Avatar
magnethead
fuel pump for a dakota should not be $800. You can swap to a Walbro for that price. Should be like $250. Should see 49 PSI at the fuel rail constant.
Old May 15, 2018 | 09:17 PM
98DAKAZ's Avatar
98DAKAZ
Cool
Its the labor that kills ya $200 parts $600 labor called 4 shops all around $800.
I just dont have the time to do it and the AZ heat is on already hitting over 100 so lazy time pay a shop to do it.
Oh magnethead they checked the fuel sync its within 3 degrees they say thats good they ran a full diagnostic on my Dakota found nothing other than the fluctuating fuel pressure its worse at idle.
Two days back I was giving it a hard run and it just fell flat on its face at high rpm.
Original fuel pump 20 years it was past due to be replaced
Old May 15, 2018 | 09:55 PM
magnethead's Avatar
magnethead
Ah, labor will kill you indeed. They'll bend you over for 4 hours when it's 30 minutes to remove the 4 bed bolts and lift it off, 30 minutes to put it back on. Changing the pump itself is like 20 minutes.
Old May 15, 2018 | 10:19 PM
98DAKAZ's Avatar
98DAKAZ
Cool
Not too much you can do about it yea it sucks but with the heat and at 61 with my blood anemia problem I just don't have the strength or endurance these days. I just made R/R the engine it beat me up and wore me out.
Its getting physically challenging for me now it sucks.
