When run AC truck over heats
Old Jun 1, 2018 | 07:21 PM
Richard Young's Avatar
Richard Young
Default When run AC truck over heats
When I run the AC the truck Temp will climb and overheat
Old Jun 1, 2018 | 08:29 PM
magnethead's Avatar
magnethead
What year and engine? Does the fan get louder at all?
Old Jun 1, 2018 | 08:39 PM
Richard Young
Default Ty
2003 v6 fan never gets loud that I've noticed
Old Jun 1, 2018 | 11:15 PM
magnethead's Avatar
magnethead
Should be an electric fan that comes on at 210 degrees or with AC, as well as a clutch fan which should lock up to water pump speed somewhere around the same 210-220 window.
Old Jun 2, 2018 | 11:34 AM
98DAKAZ's Avatar
98DAKAZ
Post
I would suspect either a clogged radiator or worn out water pump or both.
It may be time for a cooling system overhaul new rad, pump hoses and stat its worth it if you have the 3.7 that engine doesn't take overheating well it leads to engine failure.
A new clutch fan also
