P0320, Intermittent Stalling, Won't Restart.
Old Sep 9, 2018 | 05:28 PM
Motega's Avatar
Motega
Question P0320, Intermittent Stalling, Won't Restart.
My 1998 2.5L Dodge Dakota Has been giving me some trouble. Its Starts fine but after running for 20 mins if I turn it off it wont start untill it "cools down" a bit or if I push start it. On some occasions it will stall when going at very slow speeds(Pulling into the driveway, going over speed bumps, stop signs, etc. I've already replaced the ignition coil, cable and plugs and MAP sensor. I had a friend scan it and I get a P0320 Error code. After researching I've noticed it could be either the Camshaft position sensor or the Crankshaft position sensor. My question is which could be likely or is the any way to be sure before continuing this guessing game.
Thanks in advance
Old Sep 9, 2018 | 06:23 PM
Cam sensor is cheaper, which means, it is more likely to be the crank sensor.
Get a Genuine Mopar sensor. Our trucks don't always care for the aftermarket fellers.
