Lifter replacement.
Old Sep 13, 2018 | 09:05 PM
byronpen's Avatar
byronpen
Default Lifter replacement.
99 Dakota 5.2
Does the intake need to be removed for the lifter to be pulled or can you pull them from the head?
I want to know if i need to get the old bolts sprayed.
I had a jeep with a 5.2 and didnt need to pull the intake.
Old Sep 13, 2018 | 10:05 PM
magnethead's Avatar
magnethead
Depends on which cylinders. You don't have to, but it makes life easier.
Old Sep 14, 2018 | 12:57 AM
tonypilot7's Avatar
tonypilot7
Don't you have to remove it to take this bracket off? Or can you pull the lifters without removing it?
Old Sep 14, 2018 | 07:06 AM
byronpen's Avatar
byronpen
can anyone confirm this.
Simply does the intake have to come off> i cant find a definite
Old Sep 15, 2018 | 08:56 AM
Yes. There is no way to pull the lifters out of the engine with the intake in place. They sure as heck aren't going to fit thru the pushrod holes in the heads.
