Water on passenger side
Old 09-19-2018, 08:01 PM
djacobson's Avatar
djacobson
djacobson is offline
Default Water on passenger side
Darn I just thought the AC drain was plugged Rusted right to the inside where the AC water goes.
Old 09-20-2018, 08:48 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,210 Likes on 2,961 Posts
Well, that would explain a lot....
Old 09-20-2018, 09:29 PM
magnethead's Avatar
magnethead
magnethead is offline
There's not even a good way to fix that, either. All you can really do is band-aid oit by pop-rivetting some sheet metal over/around the hole where any good steel still exists
Old 09-21-2018, 08:07 AM
djacobson's Avatar
djacobson
I cut back until I got good metal. Painted everything with Rust Bullet paint. Pounded a piece of sheet metal to fit and cover the entire area.Rust Bullet on the patch. Riveted on with ample amounts of RTV to ensure the seal. Top coat with rubberized undercoating. Now besides welding the patch on what would have been the better way? Welding would have created a lot of issues with the inside tar like panels. Rivets are perfectly fine. I also put a little elbow on the AC tube to make the water go out more and "adjusted" the heat shield so the water flows in front of the shield instead of behind the shield and down the firewall.
Old 09-21-2018, 11:22 PM
magnethead's Avatar
magnethead
That's really all you can do. A tacking TIG style weld could minimize the heat to other panels, but they'd likely still melt....and it takes for effing either to make a couple hundred tacks.
Quick Reply: Water on passenger side
