Right side front end noise/vibration
Old Nov 6, 2018 | 01:21 PM
Elkido122's Avatar
Elkido122
Default Right side front end noise/vibration
My 2000 dodge Dakota 4wd has been having front end noise. When I take it for a drive and turn the wheel to the right it goes away completely . So I decided I would change that wheel bearing out , sure enough it’s still there . It happens from about 20 miles an hour to whatever speed I’m going in a certain area .
Old Nov 6, 2018 | 07:56 PM
magnethead's Avatar
magnethead
As I recall, wheel bearings are opposite, and the noise goes away when the tire is pushed outward (the inside bearing is usually the one to go). Thus, going away when you turn right would be unloading the left front inside bearing.
Old Nov 6, 2018 | 09:19 PM
Elkido122's Avatar
Elkido122
I was always told if you turn your wheel to the right the load is then on the left tire ? Meaning if you don’t hear it then it’s the right side somewhere making the noise ... please corrrect me if I’m wrong
Old Nov 7, 2018 | 10:07 AM
Yeah, the bearing on the inside of the turn is being unloaded. Bearing on the outside of the turn is taking more load. So, if the noise gets worse when you turn right, that would be the left bearing that is making the noise.
Old Nov 7, 2018 | 12:20 PM
Elkido122's Avatar
Elkido122
So if I replaced the right wheel bearing and when I turn right the noise goes away then what does that leave me with ? Cause the noise is still there unless I’m turning . Guess it was a waste to replace the right bearing cause it still does it
Old Nov 7, 2018 | 06:56 PM
Check and see if something isn't rubbing, like heatshields on the rotors, or something similar. (it can make a terrible noise.....)
Old Nov 8, 2018 | 02:49 PM
XSubaruJeepDude's Avatar
XSubaruJeepDude
This may be opposite from what many say but..
I have a bearing noise and vibration that "SEEMS" to come from the drivers side.
When i am in a right hand curve or in a road that is slanted to the left and there is more weight on the drivers side wheel, the noise goes away.
When i brake and put weight on the front wheels the noise goes away.
However in contrast.
When i am in a left hand curve or on a road is slanted to the right, and the weight load on the drivers side wheel is reduced, the noise gets louder.
The last mechanic to look at my truck said that the "Drivers side" bearing was going bad but could only be noticed in a road test.
SO armed with all this information...
I decided that i will replace BOTH front bearing and hub assemblies with a reputable manufacturer like Moog.
Old Nov 8, 2018 | 07:42 PM
Do the passenger side first, and take it for a drive, just out of sheer cussedness.
Old Nov 9, 2018 | 10:04 PM
XSubaruJeepDude
I will do that. but im not going to make any bets before i do
