Issue with oil change
Old Dec 2, 2018 | 11:34 PM
Thorco's Avatar
Thorco
Default Issue with oil change
Hi everyone. I just got an 01 dakota sport. It has the 3.9l v6. I just did an oil change and when I was adding the new oil it wouldnt flow down through the valves cover easily. Ive done oil changes all my life and its always flowed right down and never backs up at the oil fill hole. Do you know whats causing this and is it something I should take care of right away?
Old Dec 3, 2018 | 01:24 PM
Robertwav1's Avatar
Robertwav1
I don't know if this is normal for your year or not? I have a 98 3.9 and it takes oil as fast as I can give. It may be the oil return holes are plugged under valve covers. Had this happen a few times in my life and it was from not frequent enough oil changes. sludge builds up, oil slows down. Keep an eye on oil pressure.....
Old Dec 3, 2018 | 02:48 PM
98DAKAZ's Avatar
98DAKAZ
If its going down that slow I would pull the cover and take a look it could be sludged up bad.
Old Dec 6, 2018 | 08:36 PM
XSubaruJeepDude's Avatar
XSubaruJeepDude
Stick finger in oil filler inlet, feel for oil bottle cap or plastic bottle lock ring. Jk
