Power steering issue
Old Jan 16, 2019 | 03:25 PM
shaunboutila's Avatar
shaunboutila
Default Power steering issue
so drive my truck today and there’s basically no power steering when it’s at a low idle you can hear the pump making noise as same when your driving but have like no power steering anyone else have this issue. ?
Old Jan 16, 2019 | 06:13 PM
00DakDan's Avatar
00DakDan
Section Moderator
You did check the the fluid level?
Does it work when the truck warms up? If so, seals may not be working properly when the fluid is cold - it happens.
Old Jan 16, 2019 | 06:15 PM
shaunboutila
fluid level is full, does the same cold or warmed up !
Old Jan 17, 2019 | 10:00 AM
00DakDan's Avatar
00DakDan
Section Moderator
Could be the pump or a worn rack. A pressure test can help pinpoint.
