Signal and Hazards does not respond
Old Feb 7, 2019 | 12:37 PM
KMaguireS's Avatar
KMaguireS
Question Signal and Hazards does not respond
I have a 2002 Dodge Dakota quad cab. Turn Signal/hazards do not turn on.
Swapped out bulbs, fuse and tried new switch assembly. All lights working, but still no sound or light
inside or out when I try to signal or hit hazard button. BTW, wipers work when I
use same lever to turn them on. HELP!
Old Feb 9, 2019 | 11:16 AM
hidden1's Avatar
hidden1
Did you try swapping out the flasher relay ?
Old Feb 10, 2019 | 10:15 AM
00DakDan's Avatar
00DakDan
Section Moderator
Did you check both fuses? There is one, a 10 amp, #19, in the junction block by the drivers door. There is another, 30 amp, fuse 1, under the hood in the PDC.
