P0846 Code & Limp Mode
Old Mar 10, 2019 | 06:56 PM
savagedaughter's Avatar
savagedaughter
Post P0846 Code & Limp Mode
I replaced the throttle sensor and oil pressure sensor on my 2003 Dodge Dakota. Truck is going in and out of limp mode and giving code of P0846. Read a ton of info on this and tried resetting the TCM several times. Finally after leaving both battery cables off the battery overnight and doing a reset before starting, truck came out of limp mode. Still getting P0700 followed by P0846 code. Truck is now going in and out of limp mode and is easily resetting.
I read in the forum boards the truck may run rough for first 50 miles while relearning the computer. Sometimes it will rev before coming out of a stop. Seperately it will make a clunk sound and go into Limp Mode. Is this normal while it relearns the computer?
I plan getting the transmission censor checked. I just got the oil changed and did a fuel system cleaning on the truck a few days ago. Before I pay $600 to replace a transmission censor should I get a transmission service done on it to see if that clears it up?
Code did clear overnight but its back now and wont clear.
Thanks
