can anyone walk me through raplacing a back up light switch?
Old Mar 16, 2019 | 12:03 PM
blackdog57's Avatar
blackdog57
Default can anyone walk me through raplacing a back up light switch?
2000 Dakota 3.9 auto
Old Mar 17, 2019 | 02:49 PM
magnethead's Avatar
magnethead
If you have a digital gear indicator, it's a 5 pin switch retained by 3 tiny bolts. Be careful with the last bolt as the switch is spring loaded and will come flying out.
If you have a mechanical gear indicator, it's a 3 pin switch that screws into the transmission case.
The switch is wet at all times, so anticipate a quart or two of ATF to come out.
