98 Dakota 5.2
Old Mar 31, 2019 | 04:38 PM
Floyd Brice Dubois's Avatar
Floyd Brice Dubois
Default 98 Dakota 5.2
Starting issues solved bad ECM /PCM
Now I'm having an fuel overloading issues replaced map sensor and iac valve?
Old Mar 31, 2019 | 07:38 PM
Try the temp sensor for the PCM first.
Old Mar 31, 2019 | 08:48 PM
Floyd Brice Dubois
Default HeyYou
Temp sensor from original? Where is it located ?
Old Apr 1, 2019 | 09:08 AM
Two wire sensor, should be right close to the thermostat housing. (which makes the sensor REAL fun to get to.....)
Old Apr 1, 2019 | 09:59 AM
Floyd Brice Dubois
Default HeyYou
This sensor will me it overload and run like crap???
Old Apr 1, 2019 | 10:43 AM
Huh? If the PCM gets bad information from the temp sensor, yeah, the engine WILL run like crap. If the sensor has completely failed, the PCM will think it is -40 degrees out, and positively DUMP fuel trying to get a mixture that will burn. Now, if it ISN'T actually -40 degrees out, that will flood the motor out in short order.
Old Apr 1, 2019 | 05:11 PM
Floyd Brice Dubois
Default HeyYou
Changed the temp sensor and not even starting again
Old Apr 1, 2019 | 05:12 PM
Floyd Brice Dubois
Default HeyYou
Coil maybe?
Old Apr 1, 2019 | 06:13 PM
Was it a one wire, or two wire sensor? Did the parts store give you the right sensor?
Old Apr 1, 2019 | 10:07 PM
Floyd Brice Dubois
Default HeyYou
It was 2 wire and it looked identical
