99 dakota fog lights do not work
Old Dec 12, 2005 | 04:44 AM
5 speed's Avatar
5 speed
Default 99 dakota fog lights do not work
99 dakota with the factory fog lights.. i bought it from the original owner and he said they just stopped working one day, i replaced one of the bulbs to see if that was it and no luck im thinking maybe its the switch? what do you think
Old Dec 12, 2005 | 06:21 PM
ramfan5.9's Avatar
ramfan5.9
Default RE: 99 dakota fog lights do not work
check the fuses?
Old Dec 12, 2005 | 08:17 PM
boosteddaytona's Avatar
boosteddaytona
I have a 98 and i have the same prob. the light and fuses are both good they just dont work
Old Dec 13, 2005 | 09:36 AM
RP Racing940's Avatar
RP Racing940
Check the relay.
Old Dec 13, 2005 | 03:01 PM
5 speed's Avatar
5 speed
where is it located
LAKOTA169's Avatar
LAKOTA169
Replace the switch. They had a problem with them. Had to replace the one on my '99 R/T.
Old Dec 16, 2005 | 09:57 PM
Ringering06's Avatar
Ringering06
If it's not the switch, the relay is in the power distribution center located right behind the battery under the hood. When you snap the cover off, you can look on the back of it to see which relay it is.
Old Jan 2, 2006 | 04:27 AM
karty's Avatar
karty
Its the switch!
I have a 1999 R/T and mine went out also!
So I removed the switch and got bored! Took apart the switch and found the little copper wiper that is connected to the switch.
I used a little dab of CA glue, which you can get at any hobby shop, and put it back into place and BINGO!
They work again!
Who knows how long they will last though!
Old Jan 2, 2006 | 09:19 PM
Sa_tampa's Avatar
Sa_tampa
yeah but could the switch being bad on an 03 cause the headlights to flicker, and all the interiors and stuff?.....like everything in the lighting system flickers on mine when i have the headlights on, i got nailed last night for it
