Radiator change
Old Apr 16, 2019 | 12:59 PM
hidden1's Avatar
hidden1
Default Radiator change
Im changing out the radiator an wanted to know the size of the o rings on the transcooler lines .
Old Apr 16, 2019 | 10:50 PM
magnethead's Avatar
magnethead
Shouldn't be any O-rings. They should be flared, similar to a brake line (but much larger)
Old Apr 16, 2019 | 11:09 PM
hidden1's Avatar
hidden1
If i recall correctly last radiator had them...
There on the end on left side
Old Apr 17, 2019 | 01:23 PM
Zingo's Avatar
Zingo
I would just remove one of the old rings are take it to the hardware store and match it up. The last couple rads I changed I didn't even think of changing those rings and they've been fine though
Old Apr 17, 2019 | 01:31 PM
hidden1's Avatar
hidden1
I wanted to have em there while it is off..
I bought a assortment so i can match them .
But i also wanted to know can any o ring from auto store handle the transmission fluid ?
I also have the plumbing ones but not sure they handle it.
Thanks
Old Apr 17, 2019 | 01:40 PM
Zingo's Avatar
Zingo
I guess you would have to find information about what it's made out of, or see if the package says what's safe and what's not.
Old Apr 17, 2019 | 05:34 PM
magnethead's Avatar
magnethead
any O-ring will generally work. ATF isn't that terrifyingly acidic or basic.
Old Apr 21, 2019 | 10:48 PM
Henry Hoffmann's Avatar
Henry Hoffmann
Go to a transmission shop or dealer to get them. The heat will cause regular o-rings to fail.
