black box
Old Jun 11, 2019 | 04:58 AM
wheily's Avatar
wheily
Default black box
i was checking the vacuum servos on my heat/ac box and when i removed the passenger side kick panel a black box with several wires attached fell out...does anyone know what it is.....i should have taken a pic lol
Old Jun 11, 2019 | 07:51 AM
Yes you should have taken a pic. It Could. Be. Anything. You have the truck with you. Any markings on the box? Have you traced the wires to see where they go? Disconnect it and see what happens?
Old Jun 11, 2019 | 03:13 PM
magnethead's Avatar
magnethead
Normally, that would be the factory location for the infinity amplifier. In your case, it could be alarm or any number of things.
Old Jun 11, 2019 | 04:27 PM
wheily's Avatar
wheily
ill try and get a pic of it tonight....
Old Jun 12, 2019 | 05:04 AM
wheily's Avatar
wheily
Default here a pic
says ctm on it..
Old Jun 12, 2019 | 07:31 AM
That's looks to be factory. put it back in there.
Old Jun 12, 2019 | 08:32 AM
Dodgevity's Avatar
Dodgevity
It's factory alright. It's the CTM ....central timer module.
Old Jun 12, 2019 | 08:33 AM
Skreelink's Avatar
Skreelink
Originally Posted by wheily
says ctm on it..
The CTM is the center timer module. It's what Chrysler calls their body control module. It's responsible for things like your alarm, key fobs, light controls, door locks, etc. I think they started using them on 99 or 00+. My 98, everything is controlled via the PCM.
Old Jun 12, 2019 | 12:46 PM
magnethead's Avatar
magnethead
Ah, yes. The early years had them up next to the glovebox. When the infinity audio was introduced, the CTM moved to driver side and the amplifier took it's spot.
Old Jun 12, 2019 | 03:50 PM
wheily's Avatar
wheily
thanks for the help..i velcro d it back in cense the bracket was broke
