1998 Dakota 5.2 will not start
Old Jun 17, 2019 | 02:01 PM
bigb78's Avatar
bigb78
Default 1998 Dakota 5.2 will not start
I recently bought a 1998 Dakota and it was idling rough when first started. It would rev high then almost die. Previous owner said this started after installing new injectors. After a little bit of driving it would stop and no issues. I just did an oil change and changed the upstream o2 thinking that might be the issue. Truck seemed to be running great after that. Then Saturday a mile away from home while sitting at a light my truck just died. It would crank but will not start. There was an injector with a bad oring leaking but that oring was replaced, no change. There is fuel at the rail when cranking but idk what else to check. I'm going to do a tune up today and see what happens, plugs, cap, rotor, wires, ignition coil.
If those don't work my next step is a crank position sensor after seeing that is a common issue.
Old Jun 17, 2019 | 02:08 PM
magnethead's Avatar
magnethead
Does it try to cough if you hold the throttle blades open? Defeating the idle air control
Do the screwdriver test for spark, or use a spark plug if you have one around.
If we know it's getting air, and we know it has spark, next thing will be seeing if the injectors are firing. Should have 45-55 PSI at the fuel rail during crank and run.
If fuel or spark are missing, look at the crankshaft position sensor, as well as the camshaft position sensor (in the base of the distiributor).
Old Jun 24, 2019 | 11:02 PM
bigb78's Avatar
bigb78
Ended up finding broken spark plug wire.
