98 Dakota 5.2 4wd
Old Jun 30, 2019 | 11:49 AM
Floyd Brice Dubois's Avatar
Floyd Brice Dubois
Default 98 Dakota 5.2 4wd
Ok my question is on the rearend behind the driveshaft yoke there's a plate covering the seal is it supposed to be tight, / loose and spinning around.
Old Jun 30, 2019 | 12:21 PM
Should be semi-permanently attached to the yoke.
Old Jun 30, 2019 | 01:00 PM
Floyd Brice Dubois
Default HeyYou
I've got a lot of play when I turn the yoke right or left?
Old Jun 30, 2019 | 01:07 PM
Floyd Brice Dubois
Default HeyYou
What's the easiest way to Reve yoke nut?
Old Jun 30, 2019 | 03:48 PM
magnethead's Avatar
magnethead
The dust cover should be somewhat attached to the pinion, shouldn't be rattling.
If you have a gear/cog locker (aftermarket), 1/4-1/2 turn of the pinion is normalish - it's from the cross-shaft having a little play between the carrier and locking cogs. I thought it was alot at first, after pulling the diff cover I figured out it was okay.
A clutch-type limited slip should have a tight pinion, as should a regular open carrier (unless, like the cog type, the crosspin has wallered itself out a bit)
Old Jun 30, 2019 | 04:24 PM
Floyd Brice Dubois
Default Magnethead
The bearing behind the yoke is worn out. Not destroyed yet!!! How do I fix that dust cover?
Old Jun 30, 2019 | 05:31 PM
Tack weld it back on.
