Ignition ring light wont go off - 98 Dakota
Every search comes back with info on this light NOT working, but mine won't shut off. It happened about 2 months ago and I was able to get it to shut off by starting the truck again. I noticed it the first time before going in the house. I went out this morning and my battery was completely dead, so I suspected that this was the problem again. (Battery is brand new) After jumping it, I couldn't get the ignition ring light to go off. Doors were shut, interior lights off. I ended up pulling the fuse for parking and interior lights under the hood. I can't drive it at night without this fuse, so can anyone give me some advice here? Thank you so much!
I thought of pulling the bulb out, but I'd rather come up with a better fix than that.
Really need wiring diagrams, my favorite site for such doesn't appear to have them.
Looking at a 98 Ram truck manual..... The 'halo' lite is controlled by the Central Timer Module. Power comes in to the lamp via a pink wire, from fuse 12, to pin 3 on connector C2, ground side goes to CTM with a yellow/red wire, at pin 4. Wouldn't surprise me if the wire colors/pinout weren't the same..... but, ya never know.
I would suspect the CTM is the issue..... Or, the yellow/red wire is grounding out somewhere.
Are any other lights controlled that way? (stay on after you close the door for a bit, and then turn off?) If there are, and they are working properly, I would more suspect the wire grounding out somewhere...... (for the halo)
Ok, maybe it is the CTM. Haven't started it in two days, halo light was off when I left it. Can't find anything else malfunctioning. Battery is dead now. My question is if I can test the CTM myself or at the dealer so I don't have to order one and do the whole trial and error thing. Thanks.
I have a 97 ram . The problem was a shutdown timer in the forward area of the fuseblock it is a aluminum cylinder relay long and narrow. You have to un screw the fuse block to get to it . It is a thermal device that activates when the dome lights come on. Mine kept staying on. Then it burned itself out . Very frustrating to find as everyone was saying it was a device somewhere else! It is labeled as a timer in very small writing on the fuse block
