Brakes - No fluid at rear bleeder screws
Old Aug 15, 2019 | 11:46 AM
  #31
Greasy finger prints too! I worked on a car that the owner had replaced the pads, rotors and calipers on both sides. He cleaned the rotors before he put them on but got greasy finger prints all over them. It felt like warped rotors but it just took a shot of brake cleaner. Get Chlorine free if you can.
I can see that you are old school. I haven't seen chlorinated brake cleaner, or carb cleaner, in years. Used to make a good wasp killer.... then, in the late 90's, the EPA got ahold of 'em, and the chlorine went away. I discovered that by spraying a wasp nest, and all it did was annoy them.... (bad plan.....)
Old Aug 15, 2019 | 12:28 PM
  #32
ol' grouch's Avatar
ol' grouch
It may depend on the state you're in. Brakleen around here comes in red and green cans. Red is the chlorinated and green is non-chlorinated. I saw some the other day on the shelf. The green is the same price and just a little less in the can. I still kills wasps with starting fluid or WD-40. Starting fluid will knock them out of the air.
Last edited by ol' grouch; Aug 15, 2019 at 12:29 PM. Reason: I kant spel wurth a durn.
Old Aug 15, 2019 | 10:54 PM
  #33
magnethead's Avatar
magnethead
Brake Clean? We just use straight mineral spirits, lol. Atwoods does have a red-branded can of brake kleen that is cheap and works handy too
Old Aug 16, 2019 | 08:38 AM
  #34
ol' grouch's Avatar
ol' grouch
Brakleen is made by CRC if I remember correctly. I've used it for years. I use non-chlorinated when possible. Acetone will work, it's just easier to spray and wipe.
Old Aug 16, 2019 | 09:56 AM
  #35
ZEN357's Avatar
ZEN357
Grab a friend, park friend in drivers seat. Have said friend pump up the brakes and HOLD pressure, while you crack open a FRONT bleeder. Doesn't matter which one. Do that a couple times, and then have said friend pump up the brakes. is the brake lite off? If it is, try and bleed the rears.
Gently tap the lines with a wrench as you do this to get any air pockets to moved forward and out of the system.
Old Aug 16, 2019 | 11:25 AM
  #36
ol' grouch's Avatar
ol' grouch
I use a brass machinists hammer. I used to have a brass tack hammer but it got "borrowed". the brass won't damage a good line. If it does damage it, the line needed replacing anyway.
Old Aug 16, 2019 | 10:20 PM
  #37
magnethead's Avatar
magnethead
Oh I know. We used to go through a case of CRC a week, plus our 45 gallon parts cleaner full of mineral spirits. But Atwoods came in last year, and they carry CRC for $1 less per can than O'Reillys, and also have their own label that's another $1 cheaper per can than CRC. So now we get a dozen cans of that every week.
