Brake drums 1mm too thin after turning
Old Aug 9, 2019 | 09:43 AM
mad1ben2's Avatar
mad1ben2
Question Brake drums 1mm too thin after turning
I may get slammed for asking but... how concerned should I be about brake drums being 1 mm under the minimum thickness after being turned?
Old Aug 9, 2019 | 09:57 AM
Replace them. They are cheap, and your life depends on them.
Old Aug 9, 2019 | 10:00 AM
The specs are there for a reason.
Old Aug 9, 2019 | 01:38 PM
Dodgevity's Avatar
Dodgevity
People still turn rotors & drums? Last time I priced the difference, new was only ten bucks more.
Old Aug 9, 2019 | 02:11 PM
ol' grouch's Avatar
ol' grouch
Get new drums. I've seen them crack around the circumference and the braking surface comes off all the way. No brakes at all on that wheel and if the band that breaks off slides out of position, the wheel cylinder will blow the ends out and your brakes are toast.
Old Aug 9, 2019 | 06:24 PM
Depends on what you are buying drums for. Mine are NOT cheap..... Turning them is, provided I can find someplace that actually still does it........
Old Aug 11, 2019 | 07:59 AM
mad1ben2's Avatar
mad1ben2
Thx.... Putting new drums on today...
