Shift Cable at Transmission
Old Aug 24, 2019 | 02:43 PM
Sgreene's Avatar
Sgreene
Default Shift Cable at Transmission
Hi Everyone,
My '04 Dakota sat for a few months, went to shift it and I forced it too much and broke the cable up where it connects to the lever on the column. I found that its very hard to shift at the point where it meets the transmission. I sprayed it with PB Blaster so I was able to manually shift it but it's still pretty rigid, any idea how I can loosen it back up so it's smooth? It's impossible to see it from above. I ordered a new cable and what to be sure I fix the issue.
Thank you very much.
Old Aug 24, 2019 | 04:43 PM
magnethead's Avatar
magnethead
Which engine?
Old Aug 24, 2019 | 08:50 PM
Sgreene's Avatar
Sgreene
Originally Posted by magnethead
Which engine?
Sorry, 3.7L V6 CYL Gasoline (EKG)
Old Aug 24, 2019 | 09:07 PM
Sgreene's Avatar
Sgreene
The highlighted part is where its tough to move.
Old Aug 25, 2019 | 12:46 AM
magnethead's Avatar
magnethead
So that's a 545RFE I believe, should be same as the 4.7 and 5.7. Might be the 42RLE though. I'm honestly not sure.
Generally speaking, a rough/still selector usually leads to a valvebody issue with the rod which moves in and out based on the selector, an issue with the rooster comb and/or it's detent, or some of both.
Dropping the pan may give your first clue.
Old Aug 26, 2019 | 10:02 PM
Sgreene's Avatar
Sgreene
Thank you, I'll drop the pan and give a look.
