Spudders on restart once warmed up
Old Oct 16, 2019 | 09:40 PM
kwcabin3's Avatar
kwcabin3
Did you reset the PCM after changing the TPS? PCM needs to relearn the zero value.
I disconnected battery for 15 minutes and then reconnected, will that reset?
Old Oct 16, 2019 | 10:04 PM
kwcabin3's Avatar
kwcabin3
I hear that once I remove the cables. They need to be tied together to drain capacitors. Is that correct?
Old Oct 17, 2019 | 03:18 PM
Dodgevity's Avatar
Dodgevity
Just turn key to crank position with neg cable disconnected.
Old Oct 17, 2019 | 05:24 PM
kwcabin3's Avatar
kwcabin3
Did that and tried disconnecting for several hours. No help.
Fine as long as RPMs are above 1000
Fluctuates and stalls when I stop at stop sign or red light, or backing out of spot when I leave off gas.
Old Oct 17, 2019 | 07:23 PM
Vacuum leak?
